Now that the front skin is cut and fit I can locate and fit the D window frame and do the cut. It was really easy to make the outline using the window frame as a template. Just a few measurements to make sure the window position is the same as on the left side and away we go. Fortunately I got it right and the windows are in perfect alignment with each other.
