Alaskan Bearhawk
Bearhawk
Fuel Tank Grounding Wire
The tank grounding cables are really easy. I just used 18GA wire. I cleaned a spot on a rib with a bonding brush and secured the ring terminal with a 6-32 screw. The other end gets attached to the tab that I welded onto each tank.
Cean ground point
Wire in place
Bearhawk Home
4384
416
499
Fabric
67
187
Flight Controls
57
148
Floats
1150
Hardware
Instruments
280
518
Welding
Wheels/Landing Gear
Wheels/Landing Gear/
324
