The belly skin is next and it’s a relatively easy piece to make. I made it in two halves like Jared Yates did, figuring that at some point I’ll need to take it off. It will be much easier if it’s split in two. I just need to fit the plate and then cut the holes where the shock struts penetrate the skin. Ti was a tiny bit of finessing to get the creases in the right spot, but paying attention and having a sharp magic marker is about all you need. I broke the creases in my brake…not much is needed. It’s better to sneak up on it than try to take some of the bend out.
