The trim belcrank is like what Pat Fagan did. He put an ear off the back for the cable end bearings. I made a template based loosely on the original trim belcrank and made it larger in the middle. The bearings and spacer setup is identical to what Bob Barrows used for the aileron belcrank and I just copied that setup from the wing plans. I welded it together, fussed with the bearings a bit after the welding changed the center piece ever so slightly and put it together. It rotates nice and smooth, so now it’s time to give it a home.
