I spent WAY too much time stressing about the rear flap pulley mounts. The main reason is I saw pictures from four different projects and all four were different! So much for that. So, I made up a system of cables and bungees to simulate the flap cables in about mid-travel. The flap cables use a Y in the back of the baggage compartment to transfer the load from a single pull cable to two cables, right and left. The angle of the cable on the pulley changes as it extends and retracts, so I did the best to get it at the mid-point travel. There is no easy way to clamp those bushings to the tubes for tacking, so it took a really long time to set it up. But, once it was done I tacked it and now they are in position. On to the forward pulley mounts.
