Today I was able to bend the stringer with the jig I had made and it worked beautifully. I was able to fiddle with the shape very easily and finally got most to the supports welded in. I checked the angle of the very back part of the stringer material to the tail post. I'm going to make an inspection plate between the last fuselage station and the tail post and I wanted to make sure the angle will be a good match and it is. Next step is to finish bending the other side to match the stringer I just fit and finish welding the last two standoffs.
