Well, had a lot going on, but finally got the formers screwed in place. As I was pondering the plan of attack I had a BFO, or blinding flash of the obvious. With the outside skylight supports welded in place, I won't be able to weld the wing mounts in place correctly. So, all this to find out I just may as well weld the fittings in place and move on. But, I to have a potential plan to help things along. I just have to think about it a bit.
