Alaskan Bearhawk
Date:  4-19-2014
Brief Description:  Front Seats Part 2
Not much done today, but I did make some more progress in trying to find out the dimensions of the seat locking mechanism. There is just about zero info out there. I had to piece it all from a number of sources, but I finally got on the right track. There is one thing I still need to solve and that's how the factory seat adjusting lever clamps to the bottom of the tube that encloses the seat pin and spring and still has a solid bottom for the spring. If the base is welded to the bottom of the clamp, it can't clamp. Hmmmm...a real head-scratcher. I did borrow a set of seats from a friend to get a better idea how the factory makes the seats. I'll make a hybrid between the factory seats and what Kevin DeShazer came up with in his seat plans.
Seat rail guide and lock template
Beginnings of adjusting seat lock
Borrowed rear seat
Borrowed rear seat
