Alaskan Bearhawk
Date: 10-25-2013
Number of Hours: 1.50
Brief Description: Control Stick Assembly Part 4
I finished up the u channels for the control yokes, but in my zeal to get them done, I drilled the pivot bolt hole too big. Stupid mistake. I was so focused on the 3/8ths bushing , like I did on so many other parts, I drilled the hole to accommodate them. However, that isn't the way it is supposed to be. he side view of the pivot bolt is at the bottom left corner of the plans sheet, while the three-view is at the top. I completely missed the fact the bushing was only very small, and stacked and welded on a washer. Not the way other bushings had been done, so I had that on the brain. No worries though. I spoke with Bob about my plans for a fix and he said it was no problem and would work fine. I'll describe that later, plus I like it better than what's in the plans anyway.
Both bent
Drilling the wrong sized hole!
It's done, but is an easy fix
