Alaskan Bearhawk
Date:  2-22-2012
Number of Hours:  2.50
Brief Description:  Horizontal Stab Part 1
Today I actually started on the construction of the stab. I was able to match the first leading edge I made pretty well. I cut them both to length on the fuselage side, but left the outside a little long. I need to flatten those ends to 1/2in, so that will leave a little room for trimming. That is to match the evelator when it mounts to the back.
I also cut the aft spars to length and beveled the outside. That allows the outside rib to lay flat on the end. Next will be to smoosh the ends of the tubes and make the ribs.
Not exact, but pretty darned close.
Two of each
Two of each
The first layout of parts
