Brief Description: Fuselage Final Welding Last Part
It's finally done! I went around the fuselage and corrected all those areas the AI found the minor flaws. I then put the fuselage back on to the table to check if anything moved. I'm happy to say the fuselage dropped right back into the blocks on the table and was level and straight. Also, the motor mount bolts fit with no tweaking!
