Alaskan Bearhawk
Date:  3-25-2011
Number of Hours:  2.50
Brief Description:  Making Rudder Pedals Part 1
I wanted to try to tack all the pieces in a row to make them all the same. But, after looking at the setup I had and the potential problems for movement in the middle, I opted for a single jig. SInce the dimensions were all even, I was able to make a simple setup using a steel bar, a stack of washers 1/2in high and a 1in sqare piece of tubing. A couple of bolts and clamps later I was in business.
The result is all the tubes are in line with each other and the don't rock on a flat surface. Next is to finish welding them and then weld on the tabs where the brake cylinders attach.
1st Jig
1st Jig
2nd Jig
2nd Jig
Tacked, ready to weld
