Brief Description: Initial Rudder prep and Priming
Unfortunately, I did not get pictures of the prep for the rudder other than the priming of all of the parts.
However, as I was putting the stiffeners onto the rudder skins I did not have the backplate under the skin and when I hit it with the back rivet set it caused a crease, ultimately after reaching out to Vans and Vic it was determined that I need a replacement skin as this would eventually turn into a crack.
