Wesleys Web Site
Date:  5-28-2019
Number of Hours:  2.50
Manual Reference:  Instrument panel
Brief Description:  Assembly of the instrument panel with notched flan
Match drilled the platenuts. Counter sink for flush rivets on all platenuts as well as the top notched flange piece.
Centered the vent between the longeron notch and the outer edge of the left wing panel. Drilled out the 2.68 hole for the vent.
Deburred all of the edges on the two wing assemblies and the rivet holes. Back riveted the platenuts and notched flange to the two wings. I looked right pass the bold text that reminded me not to rivet the 8 rivets in center. so I drilled out the rivets to colapse the assembly between the two longerons
Instrument panel assembly
Vent location (I should have moved it 1/4
Vent location (I should have moved it 1/4" to the outside, since it conflicts with the main panel
Panel assembly cleoced into front of fuselage
