Wesleys Web Site
Date:  4-20-2019
Number of Hours:  3.50
Manual Reference:  Rear rudder pedals
Brief Description:  Rear Rudder pedal assembly
Removed the two bolts on both the left and right lower angles of the gear towers. Bolted on the attachment brackets and marked the inbound bolt locations. Removed brackets and drilled out the second bolt holes. Deburred an rebolted the brackets to the gear towers
