Wesleys Web Site
Date:  12-25-2018
Number of Hours:  5.00
Manual Reference:  Floor assembly
Brief Description:  Match drilling floor assembly
More deburing and separation of support angles for floor assembly. Drilled and modified edges of the flap mounting blocks.
Clecoed and set into place the forward floor pices including drilling the rear yoke mounting plate. Drilled the matching holes for the forward floor piece into the two angle mounts that help hold the floor structure/angles
Mounting blocks for flap arm
Flap arm bolted and match drilled secondary holes
