Wesleys Web Site
Date:  11-16-2018
Number of Hours:  2.50
Manual Reference:  forward skins
Brief Description:  Tank seal applied to foreward skins
I discovered that I had missed dimpling the holes for the forward cooling plate to the firewall.
I drilled a hole in some 1/4" plate and set the femail dimpling die into the plate for a bucking bar. Set the male die in the hole and with the help of Jenny, use the rivet gun to apply the needed pressure to dimple a hole. (Really worked great, didn't take much to dimple the firewall)
Then mixed up 80 kg of tank sealant and used a sandwich back with a cut corner to apply the sealant to the edge of the firewall and for rivets of the forward skin. Set pieces and clecoed the assembly together.
forward skin radius outer edge
view of the firewall and forward skin
Sealant applied to the forward side skins
