Wesleys Web Site
Date:  11-10-2018
Number of Hours:  2.50
Manual Reference:  Bottom skins
Brief Description:  Assembly of bottom skins
Clecoed on the left and right forward bottom skins. Nested both skins between the side skin and lower longeron.
Clecoed on the middle bottom skin, which proved to be difficult with the lower side rivets around the wing root. After some serious wiggling with 3/32 clecos I was able to get the copper #30 clecos into place.
I clecoed on the access doors to make sure everything fit right. I'm amazed at the tight fit/tolerance of the pieces. Van's does an amazing job.
Match drilled all pieces and then removed them for deburing.
