Wesleys Web Site
Date:  4-23-2018
Number of Hours:  3.00
Manual Reference:  Longerons
Brief Description:  Forming up the left and right upper longerons
After studying the plans and measureing 16 times. Pulled a chalkline on the garage floor. I drew the template on the floor with a sharpie. Studied the plans and measured 16 times to make sure I didn't mess up.
Set the vice on the center table and started making the bends. I found it easiest to use a piece of pipe to make the bends. Forming the two bend on the top view went great. However, once you start bending the side view things get much more complicated, especially confirming measurements with a listed 1/16 tollerance.
Once I clear my head I'll check them both one more time.
