Wesleys Web Site
Date:  12-23-2017
Number of Hours:  1.00
Manual Reference:  Flap assembly
Brief Description:  Mount the Flap hinge for left wing
Positioned the flap for the 1/4" clearance between aileron and flap. Set the hinge and match drilled the hinge. ( I decided to connect the hinge mount system with option B, center hinge pins, so I will cut the pin in half and push them in from the center to each end and safety them in the center. I cut away the two eyelet on the wing side and one eyelet on the flap side.)
