Wesleys Web Site
Date:  5-9-2017
Number of Hours:  2.25
Manual Reference:  Leading edge
Brief Description:  Rivet right leading edge to main spar
I riveted the leading edge ribs to the main spar on the Right wing. Accessing the shop head was difficult since the access holes were small and you had to hold the rivet gun vertical with preasure to keep the rivet in the hole, reaching through the access hole with a bucking bar to rivet leading edge assembly to main spar.
I used a pneumatic rivet squeezer to rivet the skin to the main spar assembly. Completing everyother rivet on the top and bottom of both left and right leading edge. Pulled clecos and we are ready for one last push on the leading edge pices.
