Wesleys Web Site
Date:  2-18-2017
Number of Hours:  8.00
Manual Reference:  Fuel Tanks
Brief Description:  Fuel tank assembly. Fuel caps, drains, and vent l
Completed the assembly/platenuts for left wing access panel with anti obstruction bracket. Debur, dimple, coutersink, and rivet. Set into place the filler necks/caps and both drains holes. (Debur, dimple/contersink as required) fabricated the bracket for the breather line on one tank.
Reveived the replacement wire/shepard crook wire. Formed the bracket and adjusted travel. (I did check both sending devises 345 -42 ohms)
Measured and set the fuel sending devises into the baffle for inverted flight. I centered them between second and third rib. (I did have a mistake setting the second sending devise. --I did'nt mirror the platenuts and I had to make a second hole for the sending devise and a cover plate to rivet and seal up the mistake. I will photo the correction as I seal up the back baffle.)
Top of filler neck / fuel cap assembly
Breather line and bracket on filler neck
Breather line and hardware w/ flared  end
