Wesleys Web Site
Date:  4-25-2016
Manual Reference:  Left Elevator Trim
Brief Description:  Trim Tab assembly for left elevator
Finish bending on trim tab. Match drill the tab horn pieces, cut pre edge, dimple and rivet horn pieces to tab.
Dimple trim tab.
I messed up the An257-p2 piano hinge. I was off by 1/8" and drilled set hole too close to the edge of the hinge. (Ordered replacement Hinge on 4/26/16) Trim tab assembly will need to wait for replacement part.
