Brief Description: Cuttting and fitting on the canopy skirt
More cutting and fitting on the canopy skirt.
Built the hole duplicator for the frame to skirt holes. Marked the final canopy adhesive line to confirm prep on the plexiglass and where the Sika will fit in relationship to the skirt and plexiglass.
Set up the skirt on the table and glassed over the underside and filled the top and bottom seam to allow me to remove the metal support.
Rear spanning metal support and fiberglass work above and below support
