Brief Description: Cutting and fitting the canopy skirt
Started out with some light sanding on the control points previously glassed in.
Moved to the canopy skirt fitting again. I measured the long reach clamps from work and they should work to sika on the connection point of the fiberglass skirt to the plexiglass canopy. I marked off the rivet points on the welded canopy frame for clecos and rivets to hold the skirt. I make the final top cut on the right skirt. Fitted and marked the tranistion seam for the rear canopy and cut the two skirts. Using a piece of aluminum for the connection plate to hold the two halfs together, I drilled and clecoed the connection plate. I will need pull the two halfs together a little tighter and form up the rear slider rise.
