Brief Description: mounting control sticks and assembly
Disassembly of the control stick assembly and the interesting clearance to thread the assembly/push-rod through the opening in the bulkhead.
Measureed the 3/4" clearance on the forward rod-end bearing and the 1" clearance from the jam nut on the rear rod-end bearing. Mount assembly to fuselage tab on bulkhead and rear bracket.
I still need to review the grip clearance to cut the forward control stick before remounting in to the assembly
