Brief Description: Temporary mount the vertical stabilizer
Pulled the vertical stablizer down from storage, where it's been for the past 3 years. Unbolt the rudder from the assembly. Cut off the 9/16" of the VS702 forward structure of the vertical stab. clean / debur. Clecoed on the mounting bracket to the horizontal stabilizer. Using the locating hole in the Vert. stab clecoed the stab to the rear angle on the fuselage and clamped the spacer and the forward mount into place. Ready for the squaring up the assembly and confirming alignement.
