Brief Description: Rivet pieces of the right rear skin
Started riveting the right rear side skin to the lower longeron. I think I was a little too aggressive with the edge beveling where the skin makes contact with the bottom skin. A little too much bent edge. I may need to work the aluminum a little. We'll see what it looks like once I finish the rivets. Right now I have every other rivet on the lower longeron in place and it looks like it has a bit of a wave between each rivet as the edge of the skin connects at rivet points.
