Fabricated the cable guide block L05- 09. Drilled the F/W and ran my cables. All simple enough until I was trimming the cable guide material; plastic tube with metal inner material. Wondered why it was being so hard to cut then realized my BRAKE CABLE WAS INSIDE! Sometimes I have to wonder how I manage to tie my own shoes. The cable was not cut but was very definitely marred. I don't want to loose my brakes so will replace. Amazingly I found a replacement wire locally but noted that it's working load is only 96 lbs vs the required 400+lbs called for. So, another order to Spruce. I hope I can advance the wire through the exterior cabling or I'll have to pull it off altogether.
