Alaska Sonex
Date:  3-23-2010
Number of Hours:  1.00
Manual Reference:  Brakes supplement
Brief Description:  Brake cam modification
Sonex recommends for smoother brake operation that the edgs of the brake cam be rounded over. This requires you to release the spring tension holding the shoes; there is a surprising amount of tension here. The cam then is easily removed and a small amount of material is filed off from the four abrupt eges. Easy enough.
Before.
Before.
Completed
Completed
