Alaska Sonex
Sonex
Forward Fuselage
11-21-2009
SNX-F10
Fwd Fuse Parts
Fabricated the following:
F10-08 x 2; Clip
F10-07 R/L; idler attach brackets
F10-10 R/L: Support channels
F10-11 R/L: Clip
F10-13 R/L: Seat belt attach channel
Drilled and placed bearings with bushings and appropriate hardware for F10-16 Idler Assembly- Serviced with an appropriate AeroShell lubricant.
Help is good.
Sonex Home
1111
Aft Fuselage
Elevator
FAA
Firewall forward
Forward Fuselage
48
178
Horizontal Stab
Vertical Stab
342
Work shop
