Alaska Sonex
Date:  12-19-2008
Number of Hours:  2.50
Manual Reference:  SNX T-03
Brief Description:  HS mainspar partial remake- again.
Discovered that I made T03-06 from 0.025 sheet vs the called out 0.032. Very noticable when you hold both parts in your hand. This particular part is beginning to annoy me. At least it only took about 30 minutes to make this part from scratch; this being the 4th time I've had to make it.
Corrosion proofed this part and then primed all the remaining HS parts.
Bending the sheet
Bending the sheet
This is the offensive part version 3
