Alaska Sonex
Sonex
Vertical Stab
11-18-2008
SNX-T12
Fabrication of parts
Fabricated the following: T12-08; Fwd spar channel T12-03; Upper spar channel T12-04; Lower spar channel T12-06; clip T12-09; clip T10-03; #3 rib T10-01; Root rib.
Formed T12-07, Fwd spar fitting 35 degrees up deflection.
Somewhat surprised at the amount of fabrication and forming required for this kit. Not that it's not entertaining but just vastly different from my past GlaStar project. Time consuming as well.
Bending the Fwd spar fitting
It is good. I am pleased.
Sonex Home
1111
Aft Fuselage
Elevator
FAA
Firewall forward
Forward Fuselage
48
178
Horizontal Stab
Vertical Stab
342
Work shop
