Over last few days completed the Right Forward Fuselage Side Panel. This requires careful measuring as there are no pre-piloted holes to work against. The panels include many supporting angles and gussetts to every joint. Placed AN525 bolts, washers, nuts as called out. Riveted all remaining components and sub assemblies except the aft wing attach angle and it's associated gussetts as noted. This part must be removed at some other time-prior to finall attachment.
