Finished dimpling the forward skins and ribs. Quick and fairly simple. Finished up the nut plate installation for the aileron bellcrank assembly access.
Completed all deburring and prep work.
Went ahead and fabricated the aileron pushrod assembly. Drilled my rod-end bearings for the required inspection hole. Conected the long and short aileron pushrod per SNX-W02.
Placed the aft wing skin and riveted per instruction. Placed tie down bolt. Placed the forward wing skin and riveted per instruction. Began placing the forward skin.
