Riveted the Port side of the HS skin. The upper aft edge of the HS is not riveted as elevator hinge must be fitted first. Also, I have not fitted the tips and I left off the last 12 inches of rivets so that this would be a bit easier; also a lesson learned from the vertical stab tip.
