Fabricated T12-03; Spacer, T10-02; Rib #2. Cut piano hinge material Had to remake T12-09 as part was not correctly dimensioned and was drilled inaccurately. Assembled SNX-T08-01; Main Spar assembly and SNX-T08-02; Fwd. spar assembly Began assembly of SNX-T01; Vertical Tail Assembly.
