Alaska Sonex
Date:  9-27-2008
Number of Hours:  0.00
Brief Description:  Corrosion Protection
Anti-Corrosion Plan:
1. All steel parts are (will be) powder coated.
2. All aluminum components (skins and fittings- not rivets) will be acid etched and conversion coated ("Alodined") using PPG Alumiprep solutions.
3. The entire airframe will be primed with Stewart Systems SS Primer.
4. Top coat for airframe including all fiberglass components will be Stewart Systems Eko Poly.
