Placed the engine. Bushings placed per instruction. It looks good.
Temporary placement of the exhaust to adjust fit. Needed to remove approximately 1/4 inch from each pipe to fit. It is a relief to see that I should have no issue mounting my heater muff. Also drilled my EGT probes. After cutting to fit did final placement of exhaust and torqued to spec. Also placed intake and hung the AeroCarb. Drilled to fit.
Drilled and placed my CHT probes.
Finished the spar tunnel where I had been waiting for some differently sized rivets. It is not entirely simple to get the riveter in there but it can be done.
Replaced the flap drive tube and brake/flap handles which had been removed while drilling the wing attach blocks.
Also temporarily placed the stick assembly which had previously beem made.
