WAYNE'S WEB SITE
Date:  8-5-2015
Number of Hours:  8.00
Brief Description:  Fuselage and wings
Removed all masking from fuselage. Re-installed horizontal stabilizers, elevators and rudder. Rigged all surfaced. Connected wiring to trim tab and tested. Found that a wire had broken when it was pulled through the horizontal stabilizer. Trimmed wire and attached connectors. Tested trim servo. Works as designed.
Finished installing rib stringers, riveted to ribbs. Installed airleron bellcrank assembly. Installed pitot/AOA lines in wing.
