Rigged AIlerons and installed cotter pin keepers on aileron pulleys, safety wired turnbuckles using double wrap method. Added fuel to fuel tanks. 5 gallons each tank. Checked system for leaks and tightened all fittings. Found wiring issue with main solenoid. Rewired master switch properly. Added ground wire from engine block to firewall mount. Cleaned paint off of all ground connections and tightened. Turned on fuel pumps to bleed air out of system. Repaired small fuel leak at fuel pressure sender. Fuel pressure sensor is inop. I have the wrong sensor and ordered a new one. Turned over engine until oil pressure was indicated. Did not start engine.
