Discovered that I installed the aileron cables in the right wing backwards. Switched the cables so that they exit the wing correctly.
Did pre-cover inspection on left wing. Checked all bolts for tightness and cotter keys where required. Checked all rivets. Applied antichaff tape to all ribs and any sharp edges. Glued fabric to top and bottom of wing using stewart systems glue. Allowed glue to dry for 30 minutes (85 degrees today). Used iron at 250 degrees to do initial shrink of fabric. Will allow glue to cure overnight before shrinking anymore.
