Installed sight guage for right fuel tank, Pressure tested right fuel tank. Installed root rib on right wing. Modified ribs #2, 3 and 4. Installed inspection cover frame on bottom of fuselage under elevator bellcrank assembly. Discarded the plastic frame provided by Rans and fabricated an aluminum frame and cover out of .02 6061 aluminum sheet. Also fabricate an additional frame and cover for access to battery box from right side of fuselage.
