WAYNE'S WEB SITE
RV-8
clecoed elevator frame together ,drilled. Fabricat
Clecoed and match drilled E-601PP and E-611PP to E-702 and E-00001A & B
Fluted E-703 and E-704 ribs
Clecoed E-703 and E-704 ribs to E-702 spar and match drilled. Removed ribs from spar.
Installed E-714 counterweight to front of ribs and clecoed on E-713 skin to secure it.
Drilled pilot holes for E-714 E-713, then removed E-714 to drill hoes out on drill press.
Replaced E714 and used it as a pilot to drill holes through to front of ribs E-703 and E-704
Trimmed E-714 to size by drilling a 1/2 inch hole for a radius then the band saw to square it off.
clecoed and match drilled
Drilled to #12
Counterweight trimmed
RV-8 Home
423
Elevators
25
73
Fiberglass/Composite
Horizontal Stabiler
Intro
Shop Tools
Vertical Stabilizer
RV-8 Home
