WAYNE'S WEB SITE
RV-8
Riveted Rear HS spar
Riveted HS-609PP bars to HS-603 Spar channels
Rivetted HS-412PP and HS-413PP hinge brackets to spar
Bolted HS-411PP Center bearing assembly to spar to 25 inch lbs
HS rear spar clecoed
HS-411 Center bearing bolted on
HS-413 hinge brackets rivetted
RV-8 Home
423
Elevators
25
73
Fiberglass/Composite
Horizontal Stabiler
Intro
Shop Tools
Vertical Stabilizer
RV-8 Home
