Waynes Bearhawks
Date:  8-3-2012
Number of Hours:  3.00
Brief Description:  Started control stick assembly - Part 1
Well after a week at Oshkosh I'm ready to get back into it even though I just came home off a red-eye. Starting chapter 6 in the fuselage manual the first thing to do is make the mounting brackets. This part is big enough that I can't cut it out on the metal band saw so I used a jig saw with a metal blade to cut a blank out of the big sheet of .063 first then used the band saw to cut the edges. That worked fine.
The plans call for a space of 1-1/16" between the sides (inside of the "U"l). I forgot to add the wall thickness to the pattern so my first cut out was too narrow. Kind of a dumb mistake since the wall thickness is drawn on the full side pattern on the plans - I blame it on the red-eye!
I decided to bend this one anyway just to see how it works out. What I found is it's not an easy piece to bend using a bending block and blow hammer and I didn't like the outcome so the practice piece came in handy.
I made a new pattern and cut out the part. This time I made the bends of the "U" shape in my 36" HF brake. I couldn't completely close the "U" on the brake so I cut an oak 1-1/16" x 1-1/16" block to fit inside the "U" and used the clamping action of the bench vice to finish the forming. Then I used a bending block and the vise to bend the 5/16" flanges. I left the flanges long for bending then cut the final size of the flange. This method worked much better for me for making this part.
Flat Layout
Flat Layout
Bending
Bending "U" in Brake
Finishing Bend in the Bench Vice
