Brief Description: Cargo door truss, station diagonals
Filling in the blanks - I filled in the upper and lower truss frame of the cargo door. I also finished up the diagonals on the opposite side. I also filled in the station diagonals. Everything is done aft of the forward doors except for the little cross tube for the tail wheel. I actually made one but screwed it up when I started mounting it plumb vertical instead of at a 90 degree angle to the bottom longerons. I realized I was getting tired so I called it a day.
