Brief Description: Aux tank fittings and move center rib 11
I drilled the holes for the fittings in the aux tanks. I set the aux tank in the bay to locate the fittings in the best spot.
I've also decided to flip center rib 11 by exchanging the left and right wing center rib and associated nose and aileron pocket rib. Since I hadn't planned on aux tanks I just set these per the plans. It works better to have the flange facing the tank. I drilled out the rib attach angles and made new ones. The flange now faces the aux tank and the nose rib and aileron pocket rib match.
