Well with the rod end bearing still needing to sit all day I needed to figure out something else to do. It was real tempting to swap out wings on the table but I figure I better not take the chance. I still need to make the wing skin stiffeners so that's what I worked on. I cut the blanks with the router and pulled out the 'ol particle board bending brake for the bends. I was having a hard time with the bend closest to the skin edge so I used my hand seamers for it and that worked fine. I got two of the four bent.
