Brief Description: Finished assembly of right wing
Right wing is done. I riveted the false spar, associated ribs and the aux fuel pump mount plate - that finishes off the riveting of the right wing. I assembled all the wing steal parts using the correct bolts and nuts. I used the "Bingelis wire measuring tool" to measure all bolts. I have a few sizes I'll have to order for the proper fit. All nuts were properly torqued.
Next I leveled the left wing using the support legs. I laser leveled the ends then used a fishing line stretched above the top of the main spar and measured and shimmed to level. I rived the center ribs and the aux fuel pump mounting bracket
